The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
495 Questions View all
Can hear washer but no drain no spin no...
My Kenmore 110 Quite 111 or lll series. .did not drain and now when u turn it on it makes noise but does nothing..
Add a comment
1 Answer
Chosen Solution
First unplug it for 15 minutes to allow the control panel to reset.
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Score 2
Add a comment
Add your answer
Vera Badree will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 135
