Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3189 Questions View all
New display stands out a little bit more than original one?
So I just replaced display and battery in my iPhone 5. What I noticed is that screen on the side is lifted just a little bit more than usual (0.5mm or so). Everything works fine but when you press harder on the screen you can see the usual artefacts like you'd normally see on other (unprotected) LCD displays. Is this the fault of the cheap display replacement (no gorilla glass) ? Or maybe the battery is thicker than original one ?
Add a comment
1 Answer
Chosen Solution
this is very common when you replace an iphone screen with a non iphone factory screen. the cheaper screens have the tendency to not fit exactly. One solution that should help out some is to get a really good case for the phone that will tighten the screen up somewhat. Most likely though it is because you used a cheaper screen
Score 1
That's what I thought. Thanks!
I had the problem and it was the EMI shield not installed properly. If a new display does not work check the EMI shields.
Add a comment
Add your answer
NewKind will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 54
