Repair manuals and support for 4-wheeled passenger and cargo vehicles.
11823 Questions View all
Why won't my Isuzu RodeoCar start if AC is turned on?
Car will not crank if Ac is turned on or the radio on. Turn radio and Ac off car will crank. Headlights will not come on at all. When you turn the headlights on the hazard light indicator some on but do not flash, rear windo defroster comes on, dash lights are deam. when you turn on any of the aboved the engine will rev. Battery and alternator, fuses and relays check out fine
Score 1
1 Comment
Is the battery known to be good? Any dead cells? Is it sealed or can you add water. Can you tell us what battery it is? It doesn't appear to have a full charge.
by
Add a comment
Chosen Solution
First I would be sure the battery connections are clean and tight. I assume you have done that so the next thing would be to check all the ground connections beginning with the starter. You would be amazed at the problems a loose or corroded ground connection can make.
Score 2
1 Comment:
+ agreed
by
Add a comment
Yes all battery connections are clean and tight, starter is tight and good, ground from battery is fine, (both of them) there is a ground wire touching SOMEWHERE - the neg wire going into the starter (in the column) has power to it - I feel it will take me FOREVER to find where the wires are touching.
Add a comment
Add your answer
ldyfirechaser will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 602
