How can I repair a bad headphone jack?
The jack is funky and only works if I fiddle with it and put some pressure on the plug. My fear is the 1/8" stereo jack might be attached to the logic board which would make replacing it tricky. Is this doable?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
The headphone jack is soldered to the logic board--sorry. Repair is possible if you have a donor board and are capable of some tricky soldering.
Score 2
Comments:
+ agreed or find someone to do the re-solder
by
So how much for a new logic board and is it easy to change out ? Am I better off taking it to a Mac store for repair ?
== Update ==
It is a 12" alimunim not a 15, can a new jack just be soldered on or is it only avaliable as part of the board?
by
This is one of the problems encountered when you tag a question on to someone else question. I'll delete my answer.
by
Add a comment
Add your answer
deax will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,682
