Repair and disassembly guides for guitar amplifiers.
71 Questions View all
knobs crackle and pop
old peavy amp.. knobs crackle and pop
Score 1
1 Comment
FYI - you question is not very good as it leaves a lot unanswered that requires us to guess and ask more questions that we answer. It is like saying "my car runs funny"
by
Add a comment
Most Helpful Answer
The pots (potentiometers) are dirty.
1. Get a can of deox it or other electronics cleaner.
2. Unplug amp!
3. Get inside of amp and check on the back side of pots. If there is a small hole
spray some cleaner in there and rotate knob back and forth frpm 0 -10 several times.
If there is no hole, Remove knobs and spray down the shaft in the front give it a minute to get down in there then rotate knob several times. do this to every pot.
4. Put back together and Jam
Score 1
Add a comment
Probably needs new pots (potentiometers). If you're not confident changing them yourself, ask at the local music shop - they will almost certainly know someone who you can pay to do this for you.
Alternatively, you could attempt to do it yourself - or just clean them. There are many guides on how to do this, e.g, this one: http://www.instructables.com/id/How-To-C...
Add a comment
Add your answer
cptnekg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,117
