2.3L 4cyl or 3.0L V6, 6th Generation
426 Questions View all
What's stopping my starter from getting power?
The battery is good and I just replaced my starter. I go to turn it over and all I hear is the fuel pump kick on and the switches under the dash click on. So what is stopping my starter from getting power?
Add a comment
1 Answer
Chosen Solution
Part of the starter circuit involves having the automatic transmission being in neutral or park. There's a switch on the transmission that has to be closed by the linkage. Try moving the shifter while you are trying to crank the starter. If you've got a manual transmission, the clutch may have to be pushed in, and again there's a little switch down there somewhere.
If you have a voltmeter, you can see if you are getting 12 volts to the big starter terminal, probably not, and if you are getting 12 volts to the big relay on the starter that closes the circuit to the motor. Perhaps you forgot to hook up the wire to that relay? Or if there is just a big connector plug, take it apart and clean it, blow it out with compressed air and try again.
1 Comment:
I forgot I even posted this. Thank you though. I ended up replacing the neutral safety switch.
by
Add a comment
Add your answer
Robert R. will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 102
