display glass removal using freezer method
Has anyone used the lcd freezer separator machine in the US for removing the top glass from iphone samsung etc?
Try this inexpensive solution: http://www.ebay.com/itm/131522904072?_tr...
The unit heats up the screen assembly to loosen the glue, so that you can remove it with a Molybdenum cutting wire.
Buy dry ice put screen on for 20 minutes takes 30 seconds to take of good hey
Buy block dry ice screen facing down on ice 20 minutes. Then seperate 30 seconds and of or co2 bottle in pillow case let it empty have a block of dry ice does work board and battery removed first if you have a old screen do that first to practice
can you stick it in home freezer those flas freezers are expensive
And if you would make this as the answer...
The thing you need is this... iOpener
Are you sure this would work? He's talking about separating the glass from the LCD. It's a very delicate process and if done improperly could crack the LCD screen or damage the digitizer touch screen.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 2,275
5 Comments
I would just use the heat tubes that ifixit sells...
by ETHREAL1
can U send me a link for that product?
by claude
iOpener
by ETHREAL1
That is not what I am looking for. There is a new machine coming out of chaina that is basically using a freeze method to get the top glass off the higher end cellphone models. I want to know if anyone in the US has used this machine.
by claude
Oh sorry... No I never even heard of that before...
by ETHREAL1
