iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Replaced battery but still not charging, does not even show charging
I have an iPod Classic 80 GB A1238
The problem began when it kept saying needs charged even after being on the charger for days, would never boot past that screen. After researching decided that it must be the battery and it needed replaced. I received my battery yesterday and installed it, plugged it in to the main charger but still nothing, does not even say it is charging.
Check using another main charger but still nothing and my other devices show they are charging using those same chargers.
If I plug it in to the USB port on my computer, iTunes pops up and begins loading the iPod (but the iPod does not show in the iTunes window or on the laptop, and nothing is going on on the iPod screen), but I then get an error in iTunes that says "iPod Software Update Server Could Not Be Contacted. The Server does not support this version of iTunes", there is no error code. If I press more information it takes me to all the steps to check, and I have and still nothing.
I have tried to reset it by holding down the buttons but nothing. Maybe I just got a bad battery? I am by no means a techie, so I don't know where to go from here.
Add a comment
1 Answer
Most Helpful Answer
I suspect that the old battery is fine and the power controller is messed up (not passing power to the battery) the solution, get a new logic board as the power controller is on it...
P.S. The reason iTunes gets an error is because it detects that it is an iPod from a small flash chip in it that gets powered only by USB (never powered by the controller) but when it try's to interact it gets nothing as the iPod it's self is un powered...
Score 1
Add a comment
Add your answer
Elaine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 94
