Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Question Closed
Upgrading Memory with PC Memory
I am wondering what the difference is between the DDR3, 1066 memory on a MacBook pro and standard PC notebook memory matching similar specs? can I use PC memory in my MacBook Pro?
If not, can you please explain what the differences are?
Thanks!
Add a comment
Chosen Solution
Some of the most daunting problems I have had involved PC memory in Macs. I came very close to replacing a logic board just last week because of this. Mixing Apple factory RAM with PC RAM will drive you nuts, the machine may work just fine for days and then give you a kernel panic on every boot. You don't get tone errors and diagnostic tools will not pick it up. I highly discourage you from using PC RAM, you're just asking for wrist slashing problems.
Score 2
1 Comment:
The only time I have had problems with using PC RAM in a Mac is when the wrong type of RAM is used. What I mean by type is for example if you use ECC vs non ECC or buffered/registered vs non buffered/non registered. Typically server RAM will be ECC buffered and it will be incompatible with Macs AND home PCs.
by
Add a comment
Most Helpful Answer
Yes you can use PC RAM on a Mac Just make sure the specs match and you should be fine! Go here and choose your model then check the specs to see which RAM modules you will need.
http://www.everymac.com/systems/apple/ma...
I think you need PC3-8500 DDR3 RAM but just double check the site.
Score 2
3 Comments:
+ Agreed. Sorry Mayer, but I never had problems with RAM in Macs as long as the specs match.
by
well remacberlin, you've just been lucky
by
Thanks for the rep!!
by
Add a comment
Its the same thing because Apple buys ram memory to other fabricants. Just don't mix ram memories from different fabricants. This one is a good upgrade option: http://bit.ly/f5o1Iw
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,173
