Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Questions View all
Best place for additional 1tb ssd
Am adding an evo 850 SSD to my 2008 3.06 ghz 24" iMac, and removing the redundant SuperDrive. Will best performance come from the new SSD in the old HHD bay (and moving the old HDD to the SuperDrive bay) or the other way round, or does it make no difference?
Add a comment
1 Answer
Chosen Solution
Sorry guy not so simple!
You have two different drive interfaces in this system a SATA I (1.5 Gb/s) for the HD and a PATA (80 Mb/s) which is a huge difference is throughput! Just from this the better interface for your SSD would be the SATA HD port. But... There's more!
Your current HD is a 3.5" drive unlike the SSD which is a 2.5" drive and the optical drive carrier to hold your second drive. So you have a physical size issue so you can't move your current drive over. Then there is the issue of the current HD frame needing an an adapter frame to support the smaller 2.5" SSD. But... There's more!
Now we have the SATA I/O speed issue. Most current SSD drives are Fixed SATA II (3.0 Gb/s) or SATA III (6.0 Gb/s). Remember at the top here I stated your system was only SATA I. These fixed SATA drives just won't work in your system! At least the Samsung 850 EVO you have selected will work here as it has SATA port auto sense. But, you'll will need to make sure the SSD's firmware is up to date.
But how about doing this instead!
Get a Hybrid SSHD drive to replace your current HD. With it you get the performance you are looking for with the deep SSD cache it has and yet get the deep storage of a traditional HD. As you are using the faster port there is no lag and it's cheaper!
Here's the drive you'll need: Seagate Desktop SSHD. If you review the specs sheet here: Seagate Desktop SSD Specs. Take note on the line SATA Transfer Rates Supported (Gb/s) here you'll see all three SATA data rates are listed. As its a 3.5" drive it will fit the HD frame without any issues.
Here's the IFIXIT guide you'll need to follow: iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement
Score 4
1 Comment:
Despite being told all there were all these speedbumps I was very happy with the outcome! Excellent work Dan!
by
Add a comment
Add your answer
nic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 118
