Dispensing water back into water tank
Water is being dispensed into cup and back into water tank. I have to run twice to get one full cup of coffee.
System needs cleaning, use a pipe cleaner to clear KCup tubes and run white vinegar through the system, refill reservoir with clean water and cycle it through, there is a back pressure relief that sends the water back to the tank if the system is plugged (think hot water tank).
I have a K55. How do I run a pipe cleaner through? There are screens that block the tube.
I have one of the models with a clear plastic water tank bought in 2014/2015. The pipecleaner is a good idea, but in a pinch I used a wire twist tie this is coated with a thin coat of plastic. There are several areas I made sure to clean: The filter hole looks like an X in the water tank, just wiped out littlescreens too, then the two things that !$$&* a hole in the K-cup. Sometimes the wire will go straight through to the other side, try to get the wire going UP the big !$$&* hole and down the smaller !$$&* hole. Also cleaned out the little X hole where coffee comes through to the mug. I ran two big mug fulls of vinegar and then two(or more) big tanks of fresh water through the system to get the vinegar taste out. This worked for me. Good luck to those who still have their original Keurig!!! Any more directions here's my email ltlee@gmail.com
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 79
All Time: 14,556
