Graphics Card Not Detected
hello all,i have a 2011 27 emc 2429 imac,the last month the gpu showed some problem like flashing screen,reverted images, and things like that,so i decided to replace the gpu an amd 6970 1gb with a new one amd 6970 2gb.
When i starts the mac the screen remains black and after few seconds fan runs at high speed,so i checked the led on the logic board and i saw that only the led 1 and 2 lights up ,while led 3 and 4 are always off also after the imac starts .
The problems seems that the gpu isn't detected ,anyone know wich component could be broken ?
(the gpu works on a pc and is correctly detected )
Update (05/10/2016)
ok,thanks,i think that i will sell the gpu and then i will buy a new one for mac,because i had also checked online but seems there isn't a guide or other for flash the card or bios
in the meantime i can in someway use my imac, i mean with the intel integrated graphics?
because at the moment with or without graphic card the lcd remains black and i'm a little worried that there is another problem
3 Comments
Check the GPU is compatible with macs, most hardware is not...
by ETHREAL1
Is this a replacement GPU MXM II board? Apple uses its own firmware on them and only the boards Apple used for that given model can be used.
by Dan
this is the exact replacement that i bought
http://www.aliexpress.com/item/for-AMD-M...
is always the same model but it's 2gb instead of 1gb
by teck96
