blinking 2x stops and blinks 5 times
Mine is blinking 2x stops and blinks 5 times then stops then blinks 2 times then stops then blinks 5 times and stops
Hi @Blakelynn,
A 2 - 5 error code in a Sharp TV (if this is what you have got) indicates a problem with the power supply. Suggest that you unplug it and take off the back and initially check for bulging or leaking capacitors or any evidence of stressed components, e.g. burnt components or heat(burn) marks on the boards. If nothing is obvious it may be a faulty power supply board
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 29
