A series of 40 inch LCD HDTVs by Sony.
158 Questions View all
Will not turn on
Our tv will not turn on. There is power to the plug. Is there a fuse that might need replacing, or do you have any suggestions?
Comments:
@jrickfrye there is a fuse (couple) on the power board. Remember there is a reason why (if it did) a fuse blows. What model # is your TV?
Rep: 1
by
Model KDL-40V5100
by
Add a comment
1 Answer
Chosen Solution
@jrickfrye here is an image that shows the fuse.
If the fuse checks ok for continuity you are having other issues with the power board. If you know how to solder, you can purchase a power supply kit that will repair most common errors with the board. Or you can replace the board.
Score 2
Add a comment
Add your answer
Rick Frye will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 61
All Time: 1,116
