The following guides will walk you through common troubleshooting and replacement issues that Pentax users have encountered. Each guide contains complete information that will easily direct you through the process.
2 Questions View all
Date/time doesn't hold when battery removed
Pretty much as above. I assume there's an internal battery that has failed or I am overlooking something. After resetting, I DO use "settings complete" and "done", but it defaults to manufacture date when battery is removed for recharging. Thanks for any help.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Hi,
According to the User manual for your camera : the date and time may be returned to the default settings if the camera is left without the battery for a long time.
This seems to indicate that there is another battery (usually user inaccessible) which is used to maintain certain settings, predominately the Date and Time.
How long is a long time? It should certainly be longer than the recharge time of the main battery.
I agree with you the settings backup battery has failed.
Update
Here is a link which shows the teardown of a WG3. At 16 seconds into the video I believe that you can see what I think is a button battery on the mainboard, (directly above the red end of the screwdriver handle). If it is a standard button type battery, these are usually not rechargeable but have a long life, especially if their function is usually performed by the main battery. They only have a very low discharge current when the main battery is removed. In some older PC's the CMOS battery was of the same type and usually lasted 6-8 years before replacement was necessary. Mind you it is a lot easier to replace them than to replace the one in the camera by the look of it
https://www.youtube.com/watch?v=l0A6MnF6...
Planned obsolescence - perhaps?
Score 3
Add a comment
Add your answer
Buddy Huggett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 260
