iPhone won't charge, it's not detected by itunes and won't boot
Days ago i was charging the iphone with an att car charger using apple usb cable without problem, it was disconnected for a few minutes but when i plug it again nothing happened (no charging) i was not worry thinking my port charger probably was dirty. As soon i get home i clean the port charger, my battery was almost at 10% so, I connect the iphone to the wall charger and nothing happen. No sound, no charging. I tried with a different usb cable and same.
I make a hard reset and the iphone never boot again. It stuck in white screen with apple logo for few minutes, then turn off itselft for a second and again white screen with apple logo, that happened till battery was dead. It show low battery i plug to charger and it never charge the battery.
I opened the iphone to charge the battery with an external battery tester/charger. First it show 2.67v after few minutes it show 4.0v Placing back the battery the iphone won't boot, stuck again in the apple logo. I tried to connect the iphone to my pc to make a restore but it was not detected. Tried to put in dfu and nothing happened. 2 times it was into recovery mode but iphone isn't detected, iphone can't put in dfu for some reason.
Was thinking in port charger becuase it won't charge and it's not detected by itunes. But everytime that it's off if plug the usb cable the iphone turn on.
What could be the reason that my iphone won't boot, won't charge and iTunes doesn't detect.
Could be the Charging usb IC U2 the problem ? Why it won't boot? Anyone?
Any help will be appreciated
Ps: English isn't my firts lenguage,
This usually happens when a bad quality car charger is being used. I would advise against using any car chargers IMO they can damage your phone. Either the battery or the charging IC is at fault.
Note: Bad quality car chargers can damage your iPhone 6's battery and power / charging IC on the logic board.
by Ben
Do you think any fault on any of those parts could prevent my iphone to boot ?
by gbbazan
A faulty battery can cause the iPhone not to boot. If you are stuck at the apple logo and unplugging the charging cable immediately causes the phone to shut off at apple logo then the battery is most likely at fault.
by Ben
