The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3362 Questions View all
iPhone went dead and won't turn on even after charging
Hello guys, I hope someone can clarify this matter to me!
So my iphone 5s golden 16Gb is 18 months old and worked perfectly until 2 months ago when it would go dead and won't turn on unless I heat its back with a hair dryer.
The first time it went dead, II kept it plugged for over 12 hours on charge with no response, then I found out in a forum that I should heat it with a hair dryer. i did it and it worked, after a minute of heat, apple logo finally appeared. I did this in 3 different occasions where the battery went completely drained and it worked!
However the battery went dead again yesterday and I heat its back 3 times. On the 3rd time, iphone finally turned but the battery level kept 1% and it didnt go up even charging, while setting up the alarm, the phone again went dead and nothing happened since then (it's been 18 hours without my phone). Do you guys think it's time to replace the battery? Just wanna make sure that it's the battery because I will replace it myself, don't have enough money to take it to repair.
Comments:
Before this problem started was the battery holding a charge?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Kinda thinking it's not a battery. You could try a lightning dock replace. To rule that out
iPhone 5s Lightning Connector Replacement
iPhone 5s Lightning Connector and Headphone Jack
iPhone 5s Lightning Connector and Headphone Jack Image
Score 1
Add a comment
Add your answer
Eduardo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 161
