Released in August 2014, the Lenovo Y50-70 Touch is part of the Lenovo's Y series of laptops. Equipped with a dedicated graphics card and a 15.6" touch screen, the Y50-70 Touch is specialized for gaming.
31 Questions View all
Why is my scream flashing?
After upgrading to Windows 10 my pc started flashing so I downgraded to Windows 8.1 but I'm still flashing. I went to the geek squad to check for a virus and they said there was none. When I got home it started flashing again. Is something wrong with the GPU or my screen?
Comments:
Hi, Try connecting an external monitor and check its' display. If it flashes too try starting the laptop in 'safe mode' to see if it still flashes?
by
Add a comment
1 Answer
Chosen Solution
Does the screen flash in any particular position ? Is it when its in the tablet mode , or tented ? Does it flicker when you wiggle it, will it work properly when you dont touch it? I have had to replace the LCD cable on this model it tends to crack in the hing from the extra flexing when set up as a tablet. If the screen does not flicker with an external monitor attached as jeyeff mentioned its probable the cable. If it still flickers you may want to reinstall drivers . If you get no joy there you may be looking at the GPU starting to fail
Score 2
Add a comment
Add your answer
Paul Amp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 75
