Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
513 Questions View all
Stick space bar & others. To hard to type.
Hey there,
So the Inevitable, Soda around computers. Only it was just the last drop or two, small graces. How do I clean the key for better operation?
Add a comment
Chosen Solution
I would not use compressed air in this case, it could spread the liquid inside the keyboard and maybe cause more damage. As rab777hp says, take off the sticky keys and clean under with rubbing alcohol. You may also lift up the top case to check if there's any soda on the internal components.
Score 2
Add a comment
I would follow this guild to get the keyboard off MacBook Core Duo Upper Case Replacement then I would clean the sticky areas with rubbing alcohol and lint free cloth.
Score 1
Add a comment
Compressed air around all the keys, then remove the keys carefully and wipe with wet paper towel, should get you back and typing in no time.
Add a comment
Add your answer
Josh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,357
