Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
147 Questions View all
Question Closed
How can I open up a screen?
Hi hello greetings
Um... i have an ipad pro 9.7 model,
and i tried to open up a screen,
But I have a problem with applying a heat.
I used iopener kit which i bought from here
And hair dryer.. With suction cup.
People says if it works, then the screen will pop up little bit, disabled tape or whatever
But Nothing happens.. I can't put a pick or card. I can't put anything..
All i got is burning hot screen. What am i supposed to do...?
How am i meant to open this?? This is not easy at all..
Add a comment
Chosen Solution
Is the screen broken, why do you want to remove the glass? A newer iPad will take more heat to loosen that adhesvive, that adhesvive is very strong, a hair dryer may not have enough heat. Is this your first time removing the glass from an iPad? Make sure your careful with the playing cards to not push them in to far to cause any damage to the internal parts.
Add a comment
Most Helpful Answer
Run through the teardown of how the iFixit team did it here: iPad Pro 9.7" Teardown
Score 3
1 Comment:
I did the same.. That iopener thing.. Doesn't work
by
Add a comment
once you poped it open place something thin in it or hold it that way and pry the sides slowly apply force but not to much.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 379
