The Mac Mini family was first introduced in January of 2005.
1039 Questions View all
Can't install anything, OS X formated
I have formated my mac completely and now it keeps ejecting apple installation media, I was able to boot into linux installation media, now i can't even boot into any installation media.i gave it to apple service and they couldn't fix a thing. I know for sure that there will be a solution please help me.
Edit:
@rj713 Thank you..
@rab777hp The machine is now in unpartitioned format.. also i can't boot from any disk... Mac just shows blank white/grey screen with a mouse pointer after pressing option key (alt key) at boot time...
Comments:
What format is it now?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I suspect you somehow formatted the drive for Linux so your computer is not currently seeing the drive. You should however, be able to boot with your install disk and then format the drive for OS 10. If unable you may need to place the drive in an external case and connect it to another unit to format it. Ralph
Score 2
Comments:
You might possibly be able to use a partitioning program to delete current partitions on that drive so you can start over. Ralph
by
Add a comment
Could you find an external firewire hard drive or external optical drive to boot from ? You can also use the firewire target disk mode to install a system on your drive via another Mac.
Score 1
Add a comment
@lemerise I was also planning to do the same thing, but I have no option to get an other Mac, since Macs are very rare in my place. I'll certainly tryout the external optical drive option.
I tried to boot from a Bootable USB flash drive and unable to do that.. because the option key doesn't list anything other than asking me the password and then leading to a blank white/grey screen with a mouse pointer..
now the startup chimess sound of mac is also disappeared..
Thanks for your reply...
Add a comment
Nothing seems to work... I can't even boot into an external usb stick or external drive.. I'm stuck.. what to do..
Add a comment
Asking you for a password? Is there any chance you set a firmware password on this? What model mac, what version of OSX did you have before you attempted to reformat it? The picture on this question shows a mini, but careful reading of your posts does not say what kind of Mac it is. I haven't seen a firmware password for years; is your Mac very old?
Add a comment
I have found that a bad hard drive will cause this same type of issue many times. I would replace the hard drive, reformat it and then reinstall the MAC OS Been there , did that.
Add a comment
Before getting new equipment, consider resetting the vram, rebooting in safe mode, and booting to single user mode and working from there. Here's an article you might look at. Best of luck.
http://www.macworld.com/article/2018853/...
Add a comment
Add your answer
Deepak will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,140
