New battery not charging, magsafe green light - Temp pb ASD report
Hi,
I bought a new battery as my previous one wasnt charging (about 500 cycles).
With the new battery i can't charge it, tried SMC reset (shift,clt,alt,power) but it boots the same with no modifications:
Coconut says that:
'ADS report:
Everything passed even the battery test, excepts:
Local machine info: Mac OS X version = 10.6.6(10J3204a) IP Address:127.0.0.1 ASD version:3S148
[11:15:00] Test Passed
[04/24/16 11:15:00] Battery: Unconsumed Battery Capacity Test (test #31) - Unconsumed Battery Capacity Test
- Checks Battery has completed less cycles than design-cycle-count and maximum capacity is greater than 80% of designed capacity.
[11:15:00] ERROR -- 255 [Unknown result-code 0xff] -- TEST FAILED
[04/24/16 11:15:00] * 1 TEST(S) FAILED * [Elapsed time = 00:00:00]
[11:15:23] ERROR -- 2 [Sensor reading above alarm point] -- TEST FAILED
[04/24/16 11:15:23] Current (IB0r) -- Battery (test #1) - Sensor Reads Within Operating Range (Current)
- Check to ensure that sensor reads within operating range.
[11:29:08] ERROR -- 1 [Theta dh too high] -- TEST FAILED
[04/24/16 11:29:08] Processor: 0 (test #1) - Whetstone Test
- Concurrent whetstone floating point unit benchmark test
[12:10:36] ERROR - -33000 [Wrong drive type.] -- TEST FAILED
[04/24/16 12:10:36] * 3 TEST(S) FAILED * [Elapsed time = 00:55:13]
->>>>> i installed the ssd into dvd place
I tried with new OEM 85w magsafe, but its not charging.
Mise à jour (25/04/2016)
Is there anything wrong with the temps and voltage?
3 Comments
up,
R5281=1.985
R5280=1.984
R7021=10.1
R7022=10.1
R7051=2.3
R7052=0
by Martel
up, anyone? have any solution?
by Martel
Thanks mayer but it does not solve the problem :( i tried and magsafe still remains green, i also tried with new magsafe OEM 85w but same issue..
by Martel
