Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
Why does my iPhone have a white screen with black lines?
I tried to turn on my iphone the other day and when I pressed the home button all I saw was a white screen that had a few thin black lines on the screen.
Everything else still works on the phone I can receive and answer calls, the touch screen still works.
Is this a problem with the connectors, or is the screen broken?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
u may need to get a new lcd screen or check the cables to see if it is jutting out even the slightest bit. when checking the cables make sure that all the tiny metal clips are there and none are missing from the rows.
Score 1
Comments:
One of the cables was not plugged in all the way. Thank You.
by
Add a comment
hey man what cable was the one that wasnt plugged in cuz i have the same prob was it #1 2 or 3?
Comments:
Check cable #1 Zee.
by
ahh okay i checked it its fine, i dropped my iphone from about a foot off the ground and then the screen went white. its not cracked or anything is there something else i can do to fix it?
by
Add a comment
Add your answer
Maximus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 8,211
