2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
362 Questions View all
Why is my fan behaving this way?
So,I turn on my Macbook I boot into windows and launch my game... But I have extremely low fps and this has never happened before, so I update drivers and do other things in an attempt to fix my fps... After several hours, I figure out that the left fan isn t working. So I do some searching and find a "solution" that doesn t involve opening my Macbook since I have no knowledge of what to do. The solution was to bang on the bottom of my Macbook gently on the left side. And it did work, the fan started working and I confirmed that by downloading a fan control software. But after 20-30 mins it stopped working again and I had to do that solution again. I don t want to do that anymore cause it must be negatively affecting my Macbook and I want to know what s going on.
TL:Dr my Macbook fan isn t working (left) I bang on it it works but after 30mins it stops again what s happening please?
One more thing, the fan sometimes works and sometimes it doesnt. When it doesn't work it's on 0RPM
Add a comment
1 Answer
Chosen Solution
Well replace the fan, it's cheap and requires two screw drivers and is a very easy repair. While you re in there use some canned air and blow the vents out on both fans. That is possibly all it needs as you may have a build up that is preventing the fan from turning. Here's how to do it: MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement
Here's the part: MacBook Pro 15" Retina Mid 2012/Early 2013 Left Fan
MacBook Pro 15" Retina Mid 2012/Early 2013 Left Fan Image
Product
$49.99
Score 3
Add a comment
Add your answer
Joseph Akle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 75
