Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1068 Questions View all
iPhone 6s rear camera lens
The rear camera lens on the 6s has a small crack in it. The camera works fine and so far it does not seem to i,pact picture quality. I was wondering if there was a way to replace this cover?? Thanks
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Yes, but it has to be done internally. You'd follow the guided to replace the rear camera, but you'd take it one step further and use a ink pen or mechanical pencil and punch the lens out. The lens will fall out the back.
Comments:
i am trying to replace my rear camera lens too but it simply wont come out ive tried with all sorts to push it out but it wont budge... help
by
Have you tried pushing it from the inside of the phone out the back?
by
Add a comment
the rear camera lense is solder on the housing you will have to pry it. iPhone 6 Camera Lens Replacement here is the guide this for the 6 but it applies for the 6s as well
Comments:
if you see the video it doesnt come out that easy you will have to pry that bracket off. and then you can push it down easily i have done this alot.
by
Add a comment
Yeah the video and guides make this look like an easy repair, but it's pretty difficult because that bracket that holds the rear camera is riveted to the frame of the phone. Be sure to order a new bracket because it's nearly impossible to not damage the bracket during this repair.
Add a comment
نعم ممكن استبداله بقطعه جديدة
Add a comment
Add your answer
n3ra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 28
All Time: 377
