Won't boot up completely
When I start up the computer, I get the apple and the spinning ball. It spins for a couple minutes then restarts the computer. Over and over and never completely boots up.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Try a safe
(shift) boot. If that works run Utilities->Disk Utilities-> Disk First Aid->Verify Disk, & Repair Permissions
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Score 1
Comments:
Thanks for the tip. I tried it but the machine won't do anything but spin for a couple minutes then restarts on it's own - over and over. Any other ideas?
by
Nope - you could try to recover any important data (that should be on a backup but isn't). However it will cost a lot of money for recovery applications, your time, and the data may not be recoverable.
by
I have recently used Data Rescue 3 on a mac and was able to recover data to an external, you have to decide wether the data is worth the expense of this kid of software.
by
Add a comment
Most Helpful Answer
Running Disk Utilities from the disk you're trying to repair does not work well. It's kind of like working on a car engine while driving down the road. Start up from your system installation disk. Go to the second page pull down menu to Utilities - Disk Utilitiy and see if you can repair the drive.
UPDATE:
here's how to replace it: PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement
Score 3
Comments:
Disk utilities from the Software reinstall disk says the hard drive has encountered a fatal error. Looks like a new hard drive is in order. Thanks for the info.
by
Good call +
by
Add a comment
Add your answer
Chuck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,319
