2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
328 Questions View all
Broken keyboard backlight cable/connector
Hi! I took apart my A1398 MacBook and when I removed the logic board I forgot the backlight keyboard cable plugged and it snapped. The snapped part (with the connector) looks like this (I peeled a bit of the plastic to see the connectors):
http://s31.postimg.org/hvcza2pej/IMG_201...
http://s31.postimg.org/4shcqsz6i/IMG_201...
Do you think an experienced fixer might be able to solder the cable back together? Or buying the backlight keyboard (around 30-40$ in my country) and replacing it is the only option? Thank you!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
how much would the skilled solder guy charge to solder that cable back on, vs the 30-40$ charge for the back light? I would say that u would come out cheaper getting the back light, but to answer the question im not certain if that thin cable can be soldered back together and even if you do how well will it work, seems to me its so thin its almost impossible not to burn through it. but let us know how it goes
Score 2
Comments:
Yeah it's really thin and I think it's impossible to solder it, you can't even separate the 'pins'. I'll get the backlight and I'll change it, I saw it's not too hard since I don't have to take the keyboard off. Thank you!
by
yeah thank god u don't have to remove 198,000 dang screws for the keyboard....stupid apple engineers...lol
by
Add a comment
Add your answer
danysan2002 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 618
