Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Questions View all
SSD upgrade won't turn on
Hi to everyone. I did this upgrade with the ssd blade but the iMac won't turn on. The first green light turn on, but when I press Power button, this light goes off and on again and never start the computer. I had installed two differents ssds and neither works. I think the problem isn't the ssd. Any idea? Thanks!
Add a comment
1 Answer
Chosen Solution
Your diagnostic LED is saying it's the power supply. But before spending any money I would put it back into the original configuration and see if it works. What blades (specifically) are you trying to use?
Score 4
1 Comment:
Thanks for the answer! But in original configuration everything works fine. The PSU is ok :(
I'm using OWC Aura 6G
by
Add a comment
Add your answer
macnito will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 116
