A possible power supply solution
I just won an action for a Chromebook 11-1101us and noticed the power supply wasn't coming with it. Everything I read states that it needs a micro B 5.25v 3A charger.
I was thinking... I have a PC power supply sitting around that states on it's side that the 5V line supplies up to 23A. For purely charging purposes, if I splice in a cable to the 5v line, will this be a good way to charge the laptop until I get replacement adapter?
UPDATE: 4/27/16
A lot of good answers and a lot to think about...
I initially used my PS to USB cable and it was charging my battery. The battery didn't get hot, just barely warm but I decided it's too much of a risk after reading that it might blow up my battery. I ended up using a 2.1 amp ipad charger and it worked good... except it took over 24 hours to fully charge from a dead battery.
2 Comments
The HP charger that is recommended is about $23 which is actually more than I paid for the laptop.
by Dragon940 Carp
Dragon, happy that it worked for you and you can use the charger while using the computer near an AC outlet to extend battery time. Here is a fast charger that might provide the 3A. Also, can you change the chosen solution so others will go the correct route?
http://www.amazon.com/dp/B01CSCALOM?psc=...
by Whole Witt
