The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
Question Closed
dosn't always charge
Most times when i plug my iphone into my apple wall charger it registers the charge with no problem. But, sometimes it will connect and charge for a short length of time, then will randomly loose it's connection and won't charge. I try to reconnect all connections, and try different outlets ... with no luck. The only way that it will then charge is while plugged into the computer. Then when I try to plug it into the wall charger, it works no problem again. This happens randomly. What is causing this? How can i fix it?
Add a comment
1 Answer
Chosen Solution
Sounds like you need a new wall charger, buy one here.
Edit: looks like its out-of-stock ATM, either check back later or look for one elsewhere.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 972
