Repairs for most tablet computers. Because of their small size and frequent use of adhesive, tablet repair is often more involved than laptop repair.
18908 Questions View all
No BIOS, reset goes to dnx mode, waiting for fastboot command
I have a NuVision TM800A510L 8" tablet. This thing has been returned twice; I've probably been able to use it for a total of 15 minutes! This time it powers on to a wifi connection screen, shows my wifi is connected, and then goes to "checking for updates" and that's it. Loops back to first screen. Hard reset (I held volume (-) and power buttons for 10 sec) takes me to "Dnx mode, waiting for fastboot command" Hooked it up via USB to my laptop which recognized it as external media storage but would not interact with it. How can I get back the operating system and apps it supposedly came with?
Score 14
5 Comments
I have been trying to reset the tablet. It shows Dnx mode, waiting for fastboot command stays like that for a while then shuts off. Is it a virus or something wrong with the tablet. Then I try just the power button and it shows nuvision powered by android and then goes to a black screen. PLease help. Very disappointed. Would this be covered until the warranty.
by
I have a nextbook tablet ares 11 and it saids DNX fastboot mode in yellow letters
by
I have a ares 8 and need help. las3@nauta.cu
Get stock in logo. I've tried to flash TWRP but only boot temporary
Do I need to use a keyboard too?
by
make touch power whith volume donw then let power mak volume down pushed until see the menu for choice windows or android
by
I have a NuVision (older) tablet, TM0003A5500L, and I can get to the Recover Mode by turning off the laptop, then pressing and holding the On/Off button until it starts up. Immediately I pressed and held the Volume Up and Volume Down buttons. Within 5 - 10 seconds the screen begins to flash between the Recover Mode, Normal Boot Mode, Power Off Mode, and Reload Bootloader Mode. Immediately let go of both buttons. I then was able to press the Volume Down or Volume Up button to navigate between the modes. Once in a mode, select it by pressing the On/Off button. Cant tell you where to go from here because I'm a novice and every choice I've made, except Apply Update from ADB in the Recovery Mode has not fixed my problem. I've tried every other option, including wiping my data/factory reset and wiping cache partition, but nothing has worked and I don't know what to do to "apply update from ADB". Hopefully this will help you get to a helpful menu..
by
Add a comment
Most Helpful Answer
Why are people having so many problems with this product makes no sense I sent mine back twice fixed it twice got it back second time worked great till I downloaded my apps then it just shut off then when I tried to reset the %#*@ thing it stays on DNX Fastboot mode. I've had my Tablet for about 5 months and never even got to use the stupid thing.
Score 2
Add a comment
Hi felindsay,
I was able to get into the BIOS by using an external keyboard(with micro USB to USB adapter) by pressing F10 on boot. I'd try to reset the BIOS to defaults and check the boot order.
If you don't have a recovery drive, you could try a few hard shutdowns and this should prompt the Windows recovery process. You can try to run the built in recovery from there to RESET your device. This should bring it back to Out of Box.
Score 1
1 Comment:
Same thing happened to me..
by
Add a comment
I cannot get the bleeder out of restore your last system mode (Win 10), any thoughts?
Score 1
Add a comment
my hipstreet w7 brings up"entering dnx mode waiting for fastboot command " then disappears don't have a keyboard for it because i usually use the one on the tablet. i think if all else fails i might just lob it at the wall
Score 1
Add a comment
How do i get back to apps tablet is stuck on nextbooj
Add a comment
My tablet wouldnt start then I pressed power button then reset power first then reset then reset and then power and it said DNX FASTBOOT MODE.. with Teleclast logo.
I tried plugging it in via USB and computer said it failed to install the drivers for device.
1 Comment:
Same problem help
by
Add a comment
try letting the device fully die and plug back in to about 5% and turn on. work when my device froze on dnx fastboot mode.
Add a comment
Dnx fastboot mode not on teclast X98 pro?
Dnx fastboot mode reinstallation
fist :power off device
connect usb keyboard to device
power on +F7 key device
going to Bios
Main page bios Dnx fastboot select Enabled
Boot page bios Fastboot select Enabled
not close device!
disconect keyboard and connect device with usb gable to pc linux or windows
open powershell on windows pc or terminal on linux pc
past loader.efi file (device ROM) in windows powershell directory or linux terminal directory
in windows pc command: fastboot boot loader.efi
in linux pc command: sudo fastboot boot loader.efi
see waiting for devices !
go on device bios page save and exit
select : save changes and reset and then press on window yes
Waiting a little
now on device see fastboot mode page !
but bootloader is on
command: fastboot oem lock or in terminal sudo fastboot oem lock
to close boot loader
then close device :poweroff
open device power +vol down
now the device in normal fast boot mode !!!!!
it ready for flashing.
1 Comment:
hi
if tablet in normally fastboot mode then flash using app phoneflashtool
for that command sudo fastboot devices >tablet model on terminal
by
Add a comment
hi, i wanted to factory reset the intel android tabel.
i have tried the following when the device has been turned off
  1. press volume up and power button at the same time
  2. volume down and power at the same time
but leading to entering dnx modeā€¦
is this a faulty unit?
Add a comment
Add your answer
felindsay will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 102
All Time: 61,992
