Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
USB charging dock connector flex damage cause no sound on speaker
I was changing rear housing for my iPhone 6 last night and tore a tiny area of the Dock connector flex cable as indicated in yellow in above photo. I thought it would not affect anything because it is small and it doesn't look like an important passage.
However, I believe this resulted no sound on speaker. Is the cut in the way between the speaker and board?
Score -1
Add a comment
1 Answer
Chosen Solution
That cut will cause the loudspeaker to stop working as it cuts the connection on the charger port flex cable assembly. You will need to replace the whole charger port flex cable which isn't that expensive.
You can get the part from here:
iPhone 6 Lightning Connector and Headphone Jack
Guide to replace it is here:
iPhone 6 Lightning Connector Assembly Replacement
iPhone 6 Lightning Connector and Headphone Jack Image
Product
$19.99
1 Comment:
Thanks, I've order the the assembly.
by
Add a comment
Add your answer
Wooran Lee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 603
