The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3399 Questions View all
Screen assembly- is there differences between different iPhone 5?
I was just working with my friends Iphone 5s. I was trying to change the screen assembly, and I think everything went well, but the solution was bad.
Now there is vertical stripe going across whole screen, and when trying the number buttons number 0 is not working.
I took the part from my home, so I don´t know if it was Iphone 5s or another Iphone 5 part. Is there differences between those?
Should I just open the whole thing and but it back (I mean if some of the flex is badly on) or should I change the part to an another?
Score 1
Add a comment
1 Answer
It sounds like you have either a damaged digitizer cable, or it is the wrong part. To answer your question, yes, the iPhone 5 display and the iPhone 5s display are different, and an iPhone 5 display will not work in an iPhone 5s. However, to me, your problem sounds more like a damaged digitizer cable. I would just get a new part. Hope this helps.
Add a comment
Add your answer
aspi91 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 31
