Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1623 Questions View all
After removing HD, use it externally as USB 2 or USB 3?
I'm going to upgrade my MacBook Pro 13" unibody mid 2012 hard drive to an SSD and then want to use the old hard drive as an external drive. I see that I can buy enclosures with either USB 2 or USB 3 cables. Will my 500GB HD see the benefits of a faster USB 3 connection?
Score -1
Add a comment
1 Answer
Chosen Solution
Theoretically yes, but in true practice no. This gets into the drives I/O spec and what the drive is truly able to perform.
So if we look at the SATA III interface we can theoretically achieve 6.0 Giga bits per second which is faster than the USB 2.0 theoretical limit of 480 Mega bits per second and if we look at USB 3.0 which offers a theoretical limit of 5 Giga bits per second we can see it still is short by 1 Giga bit of throughput!
Now in the real world most USB 3.0 Thumb drives max out at 800 mega bits per second (100 MB/s) And most HD's can't sustain that either. Yes, some of the newest USB flash drives on the market now are pushing 1.6 Gb/s (200 MB/s) But you won't find any HD's offering that. And yes, SATA III SSD's will offer much better performance so a USB 3.0 case would make sense for it.
I would save your money and just stick with a USB 2.0 case for your HD.
FYI: Becareful with the B's! - little b is bit, the BIG B is Byte.
Score 1
Add a comment
Add your answer
Gary Griffith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 27
