Replaced HD, system does not recognize new drive
My Mac was crashing so I bought a new Western Digitial 7200 RPM drive and I wanted to install it clean.
I have a 10.6 Disc and when I boot to it I don't see any option for my hard drive.
I thought it was the cable but I put the old Toshiba drive in and it sees it fine.
Could it be the cable or the drive is not usable. Also I did format the western digital drive on another Mac to OS X Journaled Extended with GUID table.
After that I stil did not see it in the disk utility from the disc or when trying to install the OS.
Also I did use a usb sata cable and connected it to my western digital drive and it did see the drive in the 10.6 cd's disk utility But once I use the internal cable it did not see the western digital drive.
Thanks in advance.
5 Comments
Can you give us the exact model of WD HD you have.
by Dan
Your systems specs: MacBook Pro 13" 2.53 GHz Core 2 Duo
by Dan
Western Digital WD3200BEKX
by joshper85
Here's the spec sheet for your drive: WD3200BEKX
by Dan
New 3.0gb drive is showing. However when I try to install 10.11 from usb drive it starts the install then fails with the error "AN error has occured while preparing the installation. Try running the installation again.'
I already tried and fixed the time and date on the mac through the terminal.
I noticed I can't erase the drive I tried it gives an error.
by joshper85
