Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
631 Questions View all
apple hardware test error code 4sns/1/C0000008 TPCD--124?
I have a Macbook Pro early 2011 model
The hardware test give me this error 4SNS/1/C0000008 TPCD--124
Can you tell me something about this error?
and if there is any solution you can help me it
thank you
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
1 Answer
Chosen Solution
the “4SNS” in the example above means there is a problem with a system sensor, which can be a temperature sensor, a current sensor, or a voltage sensor. Now you can determine which of these is the case by looking at the final detail of the reading (TPCD--124). In this case “T” stands for temperature, but it could also be “I” for current, or “V” for voltage.
The letter following the “T,” “I,” or “V,” lets you know what component of the system the sensor is in. The following list is a breakdown of what each of these components is:
A: Ambient air sensor
B: Battery
C: Central processors (CPU)
D: DC (direct current)
e: PCI-express slot
F: FireWire port
G: Graphics processor (GPU)
H: Hard disk
h: Heat pipe (heat sink)
L: LCD display
M: Memory or memory riser boards
m: Misc. (i.e., battery chargers)
N: North bridge (motherboard controller)
O: Optical drives
P: Power bus
p: Power supply
s: Palm rests for laptops
W: Airport Wi-Fi card
Score 3
Add a comment
Add your answer
djamel edw will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 96
All Time: 1,483
