Repair guides and support for LED, LCD, HD and other Vizio TVs.
929 Questions View all
Why no sound or pix thru the HDMI inputs (no signal)
I get no tv signal from the cable box thru any of the three HDMI inputs. another tv works fine with the same cable inputed.
1 Comment
I have a vizio mod E470VL
by
Add a comment
1 Answer
Chosen Solution
Hi,
Have you proved that the TV's HDMI ports work by connecting a DVD player or some other device with a HDMI connection?
Has the HDMI connection between the cable box and the Vizio TV worked before, or is it a new setup?
If it is a new setup, check in the cable box settings menu if there are any 'advanced' HDMI settings options, such as an option for L-PCM.
If there are no HDMI options or none that solve the problem, in the cable box, it seems that the only solution is to use either a composite (red/white/yellow) or component (video - blue/green/red, audio - red/white) cable connection from the cable box if available.
Alternatively, you could try and find out if there is a firmware update available for the cable box or the TV which may overcome the problem. Here is an image which shows where to find the firmware revision for the TV.
Searching online it seems that a number of people have reported problems trying to connect a Vizio E470VL to a cable box (unspecified make) via HDMI.
Score 1
Add a comment
Add your answer
Koehler Powell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 878
