2001 SV 650 S 36.000Km - water in the oil/ creamy substance
Hi guys,
I need your help! What things could be at fault when there is a creamy substance (probably water-oil suspension) under the lid where you fill in the oil, as well as small droplets of clear water found under it? I am suspecting a seal near the waterpump and hoping very much it won't be the head gasket!
Are there any known conditions to cause these symptoms?
Cheers and thanks in advance,
Simon
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
This is usually caused by improper crank ventilation . Check the small vacuum line that runs into the breather box and follow it back to the engine . There should be a pcv valve there it may be plugged and need to be replaced.If the breather filter is plugged this can also cause poor crank ventilation . Its not likely the head gasket as it would be a more noticeable problem , it would cause the oil to turn to what would look like chocolate milk, you would also notice a performance drop as well as overheating of the engine.
Score 3
Comments:
Great tip! Will check that possibility today and let youse know what caused it in the end! Thank you! Any other recommendations welcome!
by
Add a comment
I had this problem aswell, it was after I bought a bike that had been stood for a while. Had me worried. I was told it would disappear after a few runs. Which it did.
Add a comment
Add your answer
Si Ki will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 13
All Time: 169
