Where is the fuse on ge spacesaver xl model jvmovw002
my microwave stopped working during cooking. Where is the fuse located? Model jvm1340vw002
@ahdjr the fuse should be behind the small grille above the control panel.
See if this helps:
GRILLE REMOVAL
The top full-width grille is removable for service to some components, such as: humidity sensor, oven light, door removal, stirrer motor and flame sensor. To Remove Grille:
1. Disconnect oven power.
2. Remove Phillips-head screws (2) from grille.
3. Lift bottom of grille and push top of grille down to remove.
CONTROL PANEL
The touch control panel is made up of the key panel and control housing trim (I -piece) and the smart board. Touch control will not be available as one complete assembly. If necessary the key panels can be checked by a continuity test.
To Remove Touch Control:
1. Disconnect power and remove grille.
2. Remove I screw at top of control panel. Lift up on control to release tabs.
3. Disconnect grounding screw and connectors.
4. Lift up on control to release hinge from mounting screw (GE Models, others remove mounting screw).
Please remember that microwaves pack quite a punch and if you do not know how to repair it, please don't. Could be a very shocking experience and I'd hate to put you 6 feet under:-)
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,096
1 Comment
@ahdjr spacesaver or spacemaker?
by oldturkey03
