The HTC Desire 816 features a 5.5-inch display with a 1280x720 resolution, 13 mp rear facing camera and HTC BoomSound.
66 Questions View all
After full screen replacement, screen registers only half of touches
The lcd and digitizer was cracked so I bought a full replacement for it and installed. The screen looks great, just like the original. I bought the grade S replacement off of etradesupply.com. After playing around with it for awhile I've worked out that it still recognizes touch in all of the areas of the screen but if i sit there and tap the same areas multiple times it will only register half of the presses. This of course makes texting atrocious. Does anyone have any idea why this would be? Please and thank you for you help.
Comments:
i have this exact problem too. why nobody noticed this thread
by
i understand this is a rather old thread and you have probably did something about it by now. i'll be grateful if you let me know what you have done about it or any hints on what the problem might be.
by
Add a comment
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Answer
Most Helpful Answer
Most likely the assembly is defective or the cable was not attached properly. I would open it back up to reconnect the cable, make sure to disconnect the battery first.
I'm sorry this answer is so late, but hopefully you were able to figure things out in the mean time.
Score 4
Add a comment
Add your answer
Damien Rodrigue will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
