One of my USB Ports don't work. Tested power with USB Meter.
One of my USB ports don't work on my MacBook Pro. Tested the power with a USB Meter.
  • 1st port has power.
  • 2nd port has no power at all
Any device I plug in doesn't work on the 2nd port.
Is there anything I can do to fix this issue?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
There is a small fuse link just behind the USB port that you have burnt by plugging in an over powered device. Make sure you used the correct power unit for the device as well as make sure you use a surge suppressor for both your computer and the USB devices.
If you have access to a self powered USB hub and plug it into your bad port and then plug something in to the hub the device should work then.
Score 3
Add a comment
Add your answer
Blanco will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 76
