Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Problem with dock connector (Possible short circuit)
hi, my name is julio and i need help with my iPhone 4.
So my iPhone keeps in loop apple logo but just if it connected to a computer or a ac power adaptor. If i remove the cable the iPhone goes down. I try replacement of battery but nothing helps. I think the problem is with dock battery connector because i search a little and i found this image:
So i pick up the multimeter and i check the continuity. I note that The last pin and the first pin are on short circuit. I think that the first pin is ground ant the last is vs (red wire) so make sense the power problems but i don't know how to fix this short circuit.
I'm asking for help to solve this guys.
Thanks a lot.
Score -1
Add a comment
1 Answer
Try cleaning dock connector with isopropyl and toothbrush first. Then if that fails replace dock connector
3 Comments:
I think the problem isnt with Dock ... I just test continuity there.. I think that maybe should be a capacitor caused by water drain because the water marker apparently shoes positive ...
by
i strongly recommend you at least try a dock replacement. 5 minute job and only a few £$
by
ok, i try like you said replace the dock and still the same ...
by
Add a comment
Add your answer
julioficabem will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 114
