A 2-in-1 coffee pot/individual cup coffee maker made by Hamilton Beach. This page covers the model number 49980A.
5 Questions View all
Why is coffee leaking onto the base?
After brewing cycle keep-hot plate is covered in coffee that ran down the sides of the carafe.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Check to ensure carafe is sitting correctly on keep-hot plate. If carafe is removed from the proper position during the brewing cycle for more than twenty seconds, this problem is likely to occur.
Comments:
On model 49983, after 2 years use, it is leaking internally from deep in the bottom. Does water flow through the clear hoses? If so, perhaps one of the clamps is not sealing properly. I see now that the hose is off.
by
Add a comment
The problem on model 49983, the hose came off by itself over time and the pipe it goes on is not easily accessable. It is a deep problem. You need about a foot long needle nose pliers. I am still working on trying to get the hose on. Not easy.
Add a comment
Add your answer
Daniel Servant will be eternally grateful.
Past 24 Hours: 15
Past 7 Days: 134
Past 30 Days: 514
All Time: 834
