The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
LCD needs to be replaced
How do I replace the LCD? Do I have to remove the keyboard or can I just remove the bezel?
Score 1
Add a comment
Chosen Solution
You can just remove the bezel.
Score 2
Add a comment
Most Helpful Answer
This may be of help
https://www.youtube.com/watch?v=Wm_sLtqk...
As @gigabit87898 said you only need to remove the bezel
Score 4
Add a comment
Add your answer
jcrimson21 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 831
