Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3230 Questions View all
Why won't my iPhone4 charge when the device is powered on?
My iPhone4 will not charge with the device powered on anymore now......I have to plug it to the charger where it won't charge at all then........power it off......wait about an hour or two.......take it of the charger.....power it back on and it's fully charged....Why is this?
Add a comment
1 Answer
Chosen Solution
Either there is debris inside the charger port that needs to be cleaned, or the charger port pins are damaged.
If the charger port pins are damaged then you will need to replace the charging port assembly.
Where to get the part:
iPhone 4 Dock Connector (GSM/AT&T)
How to replace it:
iPhone 4 Dock Connector Replacement
iPhone 4 Dock Connector (GSM/AT&T) Image
Score 1
Add a comment
Add your answer
JEFF SYKES will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 19
