The repair kit didn't work..
I have purchased the xbox 360 rrod fix kit and installed everything but i still have the rrod..
Please help me..
Please help me..
Hi Willemsesley,
If you haven't already, try using this guide to reflow the motherboard on your Xbox 360. It's even worthwhile to try this before installing the RROD Fix Kit. It's also worthwhile to check the new heat sinks and thermal pads to confirm that they're seated correctly.
I hope this helps.
Terminals 261- -300 solder joints under the GPU only have pulled away from the board and
will need to be reflowed at 260c and then clapped with a stronger ( more ridged bracket ) upgrade
the kits bracket is thin cheep , weak aluminum and is not sufficient to clamp the GPU with enough force
to get you reconnected , I'll see if I can find the supplier for the 1/8 " STEEL GPU clamp and post it here .
THE CONSOLE IS SALVAGEABLE < JUST DON"T USE A HEAT GUN ON THE BOARD until you get this clap.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 194
