The storage size of the SSD can be even larger than 1 TB! As an example Samsung offers a 2 TB drive. The OS can handle it and still larger drives. The only thing holding you back is the cost of these larger SSD drives.
As to using the optical drives SATA port using a dual drive frame. Sadly, this system has an issue with the optical drives SATA port its half way between SATA II (3.0 Gb/s) and SATA III (6.0 Gb/s). Most SSD's today are fixed at SATA III and the few that auto sense the SATA ports data rate won't work reliably, you'll need a fixed SATA II drive here.
Your best bet is just to swap out your current primary drive (HD) which you currently have a 128 GB SSD with the larger drive.
What happens here is the OS and the SSD (or HD) get into a fight as the CRC check sums don't match depending on the direction of the data move. So lets say the OS has something that needs to go to the drive it sends it over the SATA connection to the drive the drive replies I got it you send ABD, the OS says back to the drive NO! I sent you ABC not ABD, here it is again.
This battle of sending and receiving goes on for a while until the given block sent is correct. But instead of this taking one transaction it took quit a few and we're only talking about a single block of stuff 512 bytes! Now when we have 100's or 1000's of blocks this taxes both the CPU & the drive creating more heat than what it should! It also means the reliability of the data could be suspect as if you shut the system down before this battle ends the transaction is lost: Now where were we in this battle the CPU or drive asks when it starts up again.
The Crucial BX200 480GB SSD is a fixed SATA III (6.0 Gb/s) drive. While the Crucial Web site will state its compatible, this is only when you swap out your HD for the SSD, not when you use the optical drive SATA port which has a known issue.
You'll need to get a Fixed SATA II (3.0 Gb/s) drive for the optical drive SATA port. Sorry ;-{
I've seen this many a time and I know its not something people see or expect so its always a bit of work explaining whats going on.
