Improved second generation Google-branded tablet with a 7" screen.
101 Questions View all
What parts should I replace after water damage?
Hi, I dropped my Nexus 7 2013 tablet into water. It is not responding and when I hold the power button, the light at the bottom flashes 5 times. I plan to fix this tablet.
There is not visible corrosion, and the screen, motherboard, daughterboard, plugs all look fine.
What parts should I replace?
Add a comment
1 Answer
Chosen Solution
Ensure that the battery remains disconnected from the systemboard until all parts have been very carefully and gently cleaned all over, with Isopropyl Alcohol 90%+ and a soft brush (you do not want to brush components off the board) and then allowed to completely dry.
Also check that the correct voltage is present at the battery terminals, by measuring the open circuit (or battery disconnected) voltage using a DMM (Digital Multi Meter-Voltmeter function).
When satisfied that you have done all you can, re-assemble the tablet and hopefully it may turn on successfully.
If it still doesn't start properly, at least you know that you can begin fault finding without having to worry about the possibility of errant circuit paths between components created by the water, (or more correctly elements, intended or not -think chlorine, fluoride, natural minerals etc, that are always present in all water, except distilled).
Score 2
Add a comment
Add your answer
Charles Li will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 225
