Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Water Damage - Error -1? Can't Restore
Hi,
Dropped my iPhone 6 in water and it turns on fine, but goes to the "Connect to iTunes" screen.
When restoring it in DFU mode or normal mode, It comes back as error -1
If i'm correct this is a baseband issue yes? Do I need to replace the baseband modem ic chip? And if I do can I use any off the internet or do I need to replace it off an existing iphone?
Add a comment
Chosen Solution
You cant replace the baseband without using factory tools to rewrite the device serial number, so this is mostly a lost cause.
Score 2
Add a comment
Use the iFixit part. It does sound like a baseband issue. The one from iFixit is going to work, or they'll give you your money back. It's a quality part, and I don't trust much else...
Add a comment
Add your answer
Brick50 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 111
