A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
713 Questions View all
How can the motherboard stop working from the hdmi port breaking?
Recently my ps4 started losing its hdmi signal. It still worked from time to time but then eventually the whole hdmi port came apart. I took the ps4 to ubreakifix and they said the hdmi being broken may have busted the motherboard and makes the system un repairable. It don't make too much sense to me since it's worked before with a messed up hdmi port. So can anybody give me an actual good explanation on what's going on or what to do? Thank you
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Your PS4 is not "unrepairable". Just because they couldn't fix it doesn't mean that it can't be fixed. Usually when and HDMI port goes out it will not cause any problems with the motherboard but it can in some cases. Even if there are solder pads or circuit traces that have been torn off of the motherboard that is still fixable.
Fixing your PS4, even if it needs the motherboard repaired should not be a problem for a good repair shop.
Score 2
Add a comment
its possible the contacts that connect the hdmi port to the board got ripped up, and off the board. theres 4 posts on the side that help align the port to the board, but on the back of the port, they solder the pins, and its possible those could of been ripped out
Score 1
Comments:
Is there any way it can be repaired?
by
Add a comment
Add your answer
Peter mogollon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 124
